Code PO302
1997 FORD PROBE
75,000 MILES • 1.5L • 6 CYL • 2WD • MANUAL
RAY*&^MANGO
misfire number two cylinder. I put in new spark plugs , wires and distributor. still misfire code, Ray
Jan 19, 2021 at 2:46 PM
SEVAG P
  • 405 POSTS
hello,
Have you checked the injector number 2? if the pulse from the control unit present, you can use a noid light for injector pulse test its the easiest way. also perform compression test at cylinder 2 compare with others.
check our links below how to fix miss fire.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
check the pictures below how to remove and reinstall injectors
Hope these procedures help, lets us know if you need more help.
Thank you.
Jan 20, 2021 at 2:43 AM
