Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
GMC
Sierra
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0300
Code po300
2003 GMC SIERRA
119,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
GLENN VAN SCYOC
MEMBER
1 POST
FOLLOW
Misfire, check engine light.
Mar 25, 2019 at 1:19 PM
SEVAG P
CERTIFIED EXPERT
Hello thanks for using 2CarPros.
For the fault code p0300 misfire run our guide.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Let us know what happens.
thank you.
Mar 25, 2019 at 1:49 PM
SEVAG P
CERTIFIED EXPERT
Misfire is a result of no proper combustion inside a cylinder that causes absence of spark, fuel or low engine compression.
Check for spark run our guide:
Check injector pulse run our guide:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Check engine compression:
Feed back the result we are interested to know the problem.
Thank you
Mar 26, 2019 at 1:31 PM
