Code p2437?
2012 TOYOTA SEQUOIA
1,555,502 MILES • 4.6L • V8 • TURBO • 4WD • AUTOMATIC
LORENZOGALVAN68
I am getting code p2437.
The vehicle is stuck in low four-wheel drive.
Sep 9, 2023 at 3:11 PM
AL514
  • 5,465 POSTS
Hello, the only code definition that seems to be coming up is "Secondary Air Injection system air flow/pressure sensor circuit Low (Bank 2). Are you using just a basic OBD 2 scan tool that only reads engine trouble codes? There might be a different code stored in another module if you can do a full system scan. I dont think the secondary air injection would cause a transmission or transfer case issues. Ill take a look for any technical bulletins or recalls. But are you getting any code definition on your scan tool?
https://www.2carpros.com/articles/in-depth-guide-diagnosing-and-repairing-automotive-transfer-case-issues
Sep 10, 2023 at 4:35 PM
