Check engine light on and code p2238
2008 TOYOTA CAMRY
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
VANESSACASTILLO412
My check engine light came on for my O2 sensor upstream so I replaced it and the light went off for about a week. Now my check engine light came back on and code p2238 is coming up. I bought the right part which was recommended, can it be the sensor again or what can be causing this code???
May 3, 2021 at 8:04 PM
Good morning,
This is an electrical issue, not a component issue. Codes do not identify failed parts, just failed systems.
I attached a flow chart for you for the code. It indicates a low voltage to the connector for the heater circuit. You need to verify the power at the connector.
Keep me updated on your results.
May 4, 2021 at 6:10 AM
