Code P2096, Post Catalyst Fuel Trim System Too Lean Bank 1?
2007 BMW X5
216,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
MARIAN1561
I have the vehicle listed above 3.0si and received the code P2096. I have changed the downstream injector. However, there does not seem to be a leak in either the upstream or downstream. Not really sure where to go from here since it does not seem like I have a leaking or broken injectors. And am not too sure if there is a working or good catalyst converter cleaner on the market. Any suggestions or someone who has run into the same issue?
Apr 14, 2023 at 6:37 PM
This can be caused by a vacuum leak or a clogged fuel filter or a bad MAF sensor, I do the vacuum leak check first. Please use this guide when the engine is cold only:
If no leaks are found, please change out the fuel filter which is a normal maintenance item. The location is in the images below. And finally, the MAF sensor needs to be replaced. Also, the location and instructions are in the images below.
This guide can help as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Apr 15, 2023 at 10:55 AM
