Code P1850
2004 CHEVROLET TAHOE
180,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RICHARD F
Intermittent check engine light, brake band solenoid circuit.
Transmission seems to shift fine.
What is a probable cause and repair?
Sep 24, 2018 at 9:24 PM
Good morning.
Can you verify the code? There is no code listed for P1850?
Sep 25, 2018 at 3:43 AM
RICHARD F
Code P1850 , brake band solenoid curcuit.
Sep 25, 2018 at 7:20 AM
Are you sure it is a P code and not a C code?
Sep 25, 2018 at 7:48 AM
RICHARD F
Thanks for your time.
You must not know GM's trouble codes very well. I can google GM and get the list of codes, just do not know what it means.
Sep 25, 2018 at 12:19 PM
I know codes inside out on all manufacturers.
Unless you gave me the wrong information on your vehicle, that code does not apply to your truck.
Sep 25, 2018 at 1:16 PM
Here is what I found on the p1850:
"P1850 Chevrolet Description
With the engine running, Transmission Control Module (TCM) High Side driver is closed, the Power-train Control Module (PCM) detects that the Band Control solenoid was commanded off and the feedback voltage was less than 2.45 volts, or the Band Control solenoid was commanded off and the feedback voltage was from 2.45 -3.53 volts, or the Band Control solenoid was commanded on and the feedback voltage was more than 4.02 volts."
I believe this code pertains to the transfer case does it seem to work okay?
Have you checked all fuses? Here is a guide to help and the fuse locations:
Check out the diagrams (below). Please let us know what you find.
Sep 25, 2018 at 3:27 PM
