When I bought car the shift pressure sensor code p1762 was showing and it seemed I would need to replace and with shift solenoid to be safe. After driving around a little it seems the weather has something to do with issue. Is it possible rain with wet conditions could be causing the sensor to not be working correct? Last few days it has been dry and it has shifted perfect. Same as last week until we got rain. Am I reading more into this. Is there something I could check. I climbed under and do not see any raw wires etc. The vehicle had been sitting a period of time before I started driving. Possibly just driving could this be making a difference. The transmission fluid was low the first time I drove and after adding fluid it seemed to have been the problem until checking the codes and the problem returning. Thanks a head for any help. Jtb
Mar 17, 2017 at 3:51 PM
