code p1706
2005 NISSAN ALTIMA
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
TATOVASO
Neutral position switch been replace, wiring information in order to troubleshoot wiring. thanks
Sep 13, 2020 at 7:44 PM
Here are the diagnostics for the code. The attached pics correlate with these directions.
________________
pic 1
On Board Diagnosis Logic
DTC Confirmation Procedure
CAUTION: Always drive vehicle at a safe speed.
NOTE: If DTC Confirmation Procedure has been previously conducted, always turn ignition switch OFF and wait at least 10 seconds before conducting the next test.
WITH CONSULT-II
1. Turn ignition switch ON.
pic 2
2. Select "P/N POSI SW" in "DATA MONITOR" mode with CONSULT-II. Then check the "P/N POSI SW" signal under the given conditions.
If NG, go to "Diagnostic Procedure" below.
If OK, go to following step.
3. Select "DATA MONITOR" mode with CONSULT-II.
4. Start engine and warm it up to normal operating temperature.
pic 3
5. Maintain the given conditions for at least 60 consecutive seconds.
6. If 1st trip DTC is detected, go to "Diagnostic Procedure" below.
Overall Function Check
Use this procedure to check the overall function of the park/neutral position (PNP) switch circuit. During this check, a 1st trip DTC might not be confirmed.
WITH GST
pic 4
2. Check voltage between ECM terminal 102 (PNP switch signal) and ground under the given conditions.
3. If NG, go to "Diagnostic Procedure" below.
EC-PNP/SW-01
pic 5
EC-PNP/SW-02
pic 6
pic 7
Wiring Diagram
Diagnostic Procedure (Step 1)
pic 8
PROCEDURE A
Procedure A (Steps 1 - 2)
pic 9
Procedure A (Steps 3 - 6)
pic 10
Procedure A (Steps 7 - 12)
pic 11
PROCEDURE B
Procedure B
pic 12
______________
Let me know if this helps.
Sep 13, 2020 at 8:56 PM
