The codes you listed do not exist. Is it possibly P0133? If so, that deals with the heated oxygen sensor/slow response. Chances are the sensor is bad. As far as the knock sensor,
it is mounted behind the start on the engine block. Here are the directions for removal and testing. The attached pictures correlate with these directions.
COMPONENT TESTS AND GENERAL DIAGNOSTICS / Note: disconnect negative battery terminal prior to removing starter.
1. REMOVE STARTER
2. REMOVE FUEL FILTER SET BOLTS
3. REMOVE KNOCK SENSOR
a. Disconnect the knock sensor connector.
b. Using SST remove the knock sensor.
SST 09816-30010
4. INSPECT KNOCK SENSOR
Using an ohmmeter, check that there is no continuity between the terminal and body.
If there is continuity, replace the sensor.
5. REINSTALL KNOCK SENSOR
a. Using SST, install the knock sensor.
SST 09816-30010
Torque: 44 Nm (450 kg.cm, 33 ft.lb)
b. Connect the knock sensor connector.
6. REINSTALL FUEL FILTER SET BOLTS
Torque: 20 Nm (200 kg.cm, 14 ft.lb)
7. REINSTALL STARTER
____________________________________________
Here are the directions for testing the heated O2 sensor. The last picture correlates with these directions.
HEATED OXYGEN SENSOR
INSPECT HEATER RESISTANCE OF HEATED OXYGEN SENSORS
a. Disconnect the heated oxygen sensor connector.
b. Using an ohmmeter, measure the resistance between terminals +B and HT.
Resistance:
Bank 1 Sensor 1: 11 - 16 ohm at 20 °C (68 °F)
Bank 1 Sensor 2: 11 - 16 ohm at 20 °C (68 °F)
If resistance is not as specified, replace the heated oxygen sensor.
c. Reconnect the heated oxygen sensor connector.
__________________________________________________________________
Let me know if you have other questions. I hope this helps.
Oct 26, 2018 at 7:20 PM
