Code p0741
2008 PONTIAC VIBE
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DALLAS WILLIAMS
  • 6 POSTS
I was driving on the interstate car suddenly quit running no signs except I was slowing down put it in neutral tried to start while coasting no go pulled to shoulder. Tried again acted like a weak battery. Got a jump same deal dash lights go dim and hear a sound like starter tried but doesn't turn motor at all. Towed it to auto zone checked codes only one was p0741. Battery is only 6 months or so old. I put the battery in my Dodge 1500 which has been sitting for a few months and it cranked it no problem, so I don't suspect the battery. I read up on the code but can't see how it could cause this problem. Checked oil it was a little low added a quart level good. I can't check transmission fluid since it won't run. Also, the temperature gauge was normal when this happened. Any thoughts?
Dec 20, 2021 at 5:26 AM
Good morning,
I would start by removing the plugs and crank the motor to see if it turns normally.
Did you verify the oil level? It sounds like the engine is locking up.
Dec 20, 2021 at 5:50 AM
DALLAS WILLIAMS
  • 6 POSTS
That's what I was trying not to think about. Can I try using a ratchet to turn it I know plugs out would make it easier just thought that would be quicker. Also, if it locked up when driving wouldn't that stop the car while in gear?
Dec 20, 2021 at 5:57 AM
DALLAS WILLIAMS
  • 6 POSTS
I am going to check that though.
Dec 20, 2021 at 5:59 AM
No, it would not.
You need to remove the plugs. It will turn hard with the plugs. You need all resistance taken away.
Dec 20, 2021 at 6:14 AM
DALLAS WILLIAMS
  • 6 POSTS
Okay, I will try that, thanks.
Dec 20, 2021 at 6:21 AM
You are welcome.
Keep me updated.
Let me know if you have any other questions.
Dec 20, 2021 at 6:48 AM
DALLAS WILLIAMS
  • 6 POSTS
It doesn't turn over same result.
Dec 20, 2021 at 8:01 AM
Okay, you have an internal failure in the engine.
You will need either a used engine or a rebuild if that is what you want.
Dec 20, 2021 at 8:07 AM
DALLAS WILLIAMS
  • 6 POSTS
Thank you Roy, don't know what I am going to do yet.
Dec 20, 2021 at 8:44 AM
You are welcome.
Feel free to follow up with questions if you need advice.
Dec 20, 2021 at 2:49 PM
