Code p0720
2010 NISSAN ALTIMA
170,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
HARRY585
I scanned my car and the code p0720 came up. It says the transmission speed sensor. I would like to know where is the transmission speed sensor is located? Would you happen to have a diagram of it?
Sep 13, 2018 at 11:57 AM
Good afternoon.
This code indicates the output speed sensor reading is missing. I would verify there is power and that the connector is not damaged.
P0720
Descriptor
Re0F09B
Re0F10A
Probable Causes
Secondary Speed Sensor
P0720 OUTPUT SPEED SENSOR
Description
The secondary speed sensor detects the revolution of the CVT output shaft and emits a pulse signal. The pulse signal is sent to the TCM, which converts it into vehicle speed.
DTC Logic
DTC DETECTION LOGIC
DTC CONFIRMATION PROCEDURE
CAUTION:
Always drive vehicle at a safe speed.
NOTE:
If "DTC CONFIRMATION PROCEDURE" has been previously performed, always turn ignition switch OFF.
Then wait at least 10 seconds before performing the next test.
1.CHECK DTC DETECTION
With CONSULT-III
1. Turn ignition switch ON.
2. Select "DATA MONITOR".
3. Start engine and maintain the following conditions for at least 12 consecutive seconds.
With GST
Follow the procedure "With CONSULT-III".
Is "P0720" detected?
YES - Go to See: A L L Diagnostic Trouble Codes ( DTC ) > P Code Charts > CVT RE0F09B.
NO - Check intermittent incident. Refer to See: Vehicle > Initial Inspection and Diagnostic Overview > Intermittent Incident.
Sep 13, 2018 at 12:55 PM
