Engine light came on although the car seems to be running okay. I was told by a mechanic that it could be cooling system issue; thermostat, radiator leak, hose leak, cooling fan. There seems to be plenty of coolant in the reservoir, but the radiator is a bit low. or it could be cooling fan relay connector or possibly flush cooling system and replace water pump.
What do you think?
What do you think?
Mar 14, 2017 at 4:15 PM
