The engine runs great but I get a po420 and po430 code. The cost temperatures are between 40 and 100 degree different from upstream and downstream locations. All four o2 sensors are new. The upstream stays steady and the downstream readings move up and down adjusting it self when throttle is depressed. At idle it stays steady as well. Catalytic converter temperature goes up when throttle is held at 2,000 rpm's and according to temperature reads on scanner the difference in catalytic converter temperature is within 20 to 40 degrees on scanner. This is driving me nuts can someone please help? Still having p0420 and p0430 codes.
Aug 30, 2019 at 12:33 AM
