Check engine light does not tell you anything but an area of failure, not the part.
203 is for the circuit indicating a wiring issue.
P0203
Descriptor
Probable Causes
Diagnose Other DTCs First
Fuel Injector 3 Malfunction
Fuel Injector Control Circuit Open or Poor Connections
Fuel Injector Control Circuit Short to Ground
Fuel Injector Control Circuit Short to Voltage or Another Circuit
Fuel Injector Control Circuit Short to Voltage or Open
Fuel Injector Ignition Voltage Circuit Open
Multi-Way Connector Poor Connections
Powertrain Control Module (PCM)
Powertrain Control Module (PCM) Harness Connector Poor Connections
Wires Inside Insulation Broken
Wiring Damaged or Pinched
Apr 21, 2019 at 3:05 PM
