Code p0410
2001 SATURN SL2
115,000 MILES • 1.9L • 4 CYL • AUTOMATIC
BLUEISMYCOLOR
  • 54 POSTS
So, I know this code is for the secondary air system. I have had it cleaned out, the air pump tested good, the filter in the air pump has been cleaned. What could keep causing this code to come up? What should I try?
Aug 30, 2016 at 6:07 AM
SATURNTECH9
  • 30,869 POSTS
So do you have a code p0410?If so you could have a leaking broken vacuum line to the combination valve on top of the AC compressor.Or the combination valve on top of the AC compressor might be bad and not holding vacuum.You can test it with a hand vacuum pump along with the vacuum source to the combination valve solenoid with the hand vacuum pump.That's the first thing I would check if you know the air pump is working.How do you know the ports in the head and the pipe going into the head are clear?
Aug 30, 2016 at 7:46 AM
BLUEISMYCOLOR
  • 54 POSTS
I will pass this info along to my friend that,has been working on my car. He has cleaned the pipe out I'm not sure about the ports.
Aug 30, 2016 at 10:29 AM
BLUEISMYCOLOR
  • 54 POSTS
How would we go about cleaning the ports?
Aug 30, 2016 at 4:44 PM
SATURNTECH9
  • 30,869 POSTS
Let's see about other things I mentioned first.Cleaning the ports in the head require removing the exhaust manifold and is labor intensive.
Aug 30, 2016 at 10:24 PM
BLUEISMYCOLOR
  • 54 POSTS
Ok. Thanks!
Aug 31, 2016 at 6:31 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep me posted
Aug 31, 2016 at 7:19 AM
BLUEISMYCOLOR
  • 54 POSTS
Would that part be called something other then a combination valve? I can't seen to find a part with that name.
Sep 1, 2016 at 6:51 PM
SATURNTECH9
  • 30,869 POSTS
So was the combo valve on top of the AC compressor not holding vacuum and your looking for a replacement?They don't make aftermarket ones it's factory only.Let me know I have the part number.
Sep 1, 2016 at 7:10 PM
BLUEISMYCOLOR
  • 54 POSTS
Oh ok. It hasn't been checked yet I just wanted to know what kind of price I may be looking at.
Sep 1, 2016 at 7:13 PM
SATURNTECH9
  • 30,869 POSTS
Maybe 65 I haven't priced one in a while let me know what you find.
Sep 1, 2016 at 7:14 PM
BLUEISMYCOLOR
  • 54 POSTS
Do I need the part number so Saturn knows what I'm talking about?
Sep 1, 2016 at 7:24 PM
SATURNTECH9
  • 30,869 POSTS
The last Saturn dealer closed Oct of 2010 I will help you find one if you need it.
Sep 1, 2016 at 8:06 PM
BLUEISMYCOLOR
  • 54 POSTS
My friend said he is going to check around but may need a part number.
Sep 2, 2016 at 6:09 AM
SATURNTECH9
  • 30,869 POSTS
So again did it test bad or are you just trying to replace parts and hope it fixes it?Iam factory trained tech and know these cars well.Rent a hand vacuum pump from auto zone to test the combo valve and it's vacuum source.
Sep 2, 2016 at 12:23 PM
BLUEISMYCOLOR
  • 54 POSTS
Ok. I was finally able to have i checked and put onto a computer. The mechanic said it is a bad solenoid. Is this the same part you were talking about?
Sep 22, 2016 at 8:09 AM
SATURNTECH9
  • 30,869 POSTS
No that's the solenoid that turns the vacuum on to the combination valve I was telling you to see if it's holding vacuum.I highly doubt it's that solenoid I have never replaced one for that code.I seen people guess they are bad and replace them and still get the code back.It's going to be hard to find one there can't be that many new ones out there and there not going to make a aftermarket one.It way more likely that you have a bad combination valve or plugged up air injection ports or a bad vacuum supply line or something along those lines.The first thing I always check first is the vacuum supply line and the combination valve.that's mostly what I have seen set those codes.
Sep 22, 2016 at 10:50 AM
BLUEISMYCOLOR
  • 54 POSTS
That is what came up in the computer he put the car on that scans the whole car. I'm not quite sure what to do at this point.
Sep 22, 2016 at 12:48 PM
SATURNTECH9
  • 30,869 POSTS
No even the factory Saturn scan tool I used use when I worked for Saturn won't say oh you have a bad air injection solenoid.We can try to diagnosis it if your willing to work with me and follow my directions ?
Sep 22, 2016 at 12:55 PM
BLUEISMYCOLOR
  • 54 POSTS
I'm sorry apparently I was wrong. It is not the solenoid it is the valve.
Sep 22, 2016 at 8:28 PM
SATURNTECH9
  • 30,869 POSTS
I will get you the part number when I get home I have one of those valves for my car .I got mine on rock auto dot com.
Sep 23, 2016 at 12:53 PM
BLUEISMYCOLOR
  • 54 POSTS
Thank you!
Sep 23, 2016 at 3:17 PM
SATURNTECH9
  • 30,869 POSTS
There is a picture of the part is that the one that is bad?Also I took a picture of the part number if you type that into the part number box on rock auto dot com.Also try eBay use the part number in the search box.
Sep 23, 2016 at 5:37 PM
BLUEISMYCOLOR
  • 54 POSTS
That is the part. Had it tested again to make sure and it tested good. This is Jillian9 me ... I just have no clue.
Sep 23, 2016 at 8:02 PM
BLUEISMYCOLOR
  • 54 POSTS
Killing^^^^
SATURNTECH9
  • 30,869 POSTS
You told me they said something was bad what was it then?
Sep 23, 2016 at 11:49 PM
