Engine code p0304 cylinder 4 misfire changed out both ignition coil and spark plug, and engine will crank but won't start. I even tried the old ignition coil and new spark plug then old spark plug and new ignition coil. I tried 2 different new ignition coils and spark plugs. I even tried "clear flood mode" and pushed the gas pedal while cranking and it almost started but sounded bad and didn't want to mess up my engine. Idk what else to check or what else it would be.
Jan 22, 2024 at 2:32 PM
