Code p0301
2008 SATURN VUE
175,000 MILES • 3.6L • 6 CYL • 2WD
CASIASADA
  • 16 POSTS
Code p0301 is popping up on my car along with the traction control light and stabilizer light is also on. Swapped fuel injectors and nothing changed spark plugs and nothing. I even bought a new spark plug to put in the number one cylinder and nothing. Bought a new coil pack for it and nothing still has changed. Has new crankshaft sensor on it along with a new mass air flow sensor and cylinder one is still popping up with a misfire.
Sep 18, 2018 at 8:02 PM
Good morning.
From your description, the only thing you have not done is a compression test to verify the cylinder can produce power.
I would start there. You can rent a tester at a parts store for this procedure.
Sep 19, 2018 at 2:50 AM
CASIASADA
  • 16 POSTS
I did a compression test and I did a fuel pressure test as well and everything is fine. I have compression in that cylinder.
Sep 19, 2018 at 3:55 PM
How much compression?
Sep 19, 2018 at 4:33 PM
CASIASADA
  • 16 POSTS
When I did it I got 125 and I had some one else do one and they never told me what they got.
Sep 19, 2018 at 5:37 PM
CASIASADA
  • 16 POSTS
Now something is draining my battery. I need to know what is wrong with this car it has been a good car up until now. I have not had any real major issues with until now. I have an appointment to take it in to the shop tomorrow to have a diagnostics done on it and I am hoping it is something simple I just need help so I can get it fixed .
Sep 19, 2018 at 5:45 PM
They will most likely look at the compression as well when they check it. They will also look to see if it something mechanical in the valve train.
You have done the basics but it leaves only something mechanical.
As far as the draining, a parasitic draw test needs to be done to see how many amps are drawing on the battery with the engine off. Once that is determined and then they will need to isolate the circuit that is causing the draw. Then they can determine what is causing the draw.
Sep 20, 2018 at 1:18 AM
CASIASADA
  • 16 POSTS
Thanks I will keep you posted on what they say it is or could be.
Sep 20, 2018 at 5:57 AM
You are welcome.
Always glad to help.
Sep 20, 2018 at 6:09 AM
CASIASADA
  • 16 POSTS
Hi, I am back. I have not got my car back but did get off the phone with the shop that is doing the diagnostics on it. They did a compression test on it and said that one side of the engine has better compression than the other side. But are also saying it could be timing chain or something to do with with a solenoid or something with the cam. I am not sure if it was the actuator or something else with the cam.
Sep 20, 2018 at 2:03 PM
Okay, that would not cause the 301 code. That will not come from the chain.
Sep 20, 2018 at 2:12 PM
CASIASADA
  • 16 POSTS
Yeah but I need to know what cause the traction control light to come on along with the stability light to come on and the check engine light flashing
Sep 20, 2018 at 2:39 PM
CASIASADA
  • 16 POSTS
After all those lights came on is when it started acting funny, but it is weird cause the traction light and stability light came on before the check engine light started flashing.
Sep 20, 2018 at 2:40 PM
The flashing check engine light is the 301 code.
The ABS and trac light is from a ABS fault. They need to pull the code and find out the failure.
Sep 20, 2018 at 2:48 PM
CASIASADA
  • 16 POSTS
But why would they come on at the same time?
Sep 20, 2018 at 2:50 PM
Cannot answer that. I am here and not there. That is what a diagnostic is for. They will look at the freeze frame data to see when and why they came on.
If they are a good shop, they should be able to give you those answers in about two hours of testing.
Sep 20, 2018 at 2:53 PM
CASIASADA
  • 16 POSTS
Left the shop and they said the variable timing is not adjusting properly.
Sep 20, 2018 at 3:41 PM
Not the 301 code and definitely not anything to do with the ABS and trac.
You need a new shop that knows what they are doing.
Sep 20, 2018 at 3:57 PM
CASIASADA
  • 16 POSTS
Okay, guess I need to take it to a GM dealer and have them take a look at it.
Sep 20, 2018 at 4:23 PM
You do not need a dealer, just a shop that will do a proper diagnostic and address your questions and give you answers.
This guy is hung up on the chain but not addressing your cylinder one misfire or the ABS issue.
Sep 21, 2018 at 1:00 AM
CASIASADA
  • 16 POSTS
True, but do not know anyone else that will or can do a proper diagnostic on it beside a dealership.
Sep 21, 2018 at 2:55 AM
I understand. Just their prices are outrageous.
Sep 21, 2018 at 3:00 AM
CASIASADA
  • 16 POSTS
Tell me about it.
Sep 21, 2018 at 8:27 AM
Let me know how you make out.
Sep 21, 2018 at 8:37 AM
CASIASADA
  • 16 POSTS
Well I took my Saturn Vue to the GM dealer yesterday 10/5/2018 and they did a compression test on that cylinder and the said they got 100 psi so the checked cylinders three and five and on both of those they got 140 psi. They wanted to take the head off to see if their was a burnt valve and I was about to agree with it until they told me it was going to cost me over two thousand dollars. So do you think it can be a valve?
Oct 6, 2018 at 9:41 AM
They can tell by airing up the cylinder and finding out where the leak is. That will tell them whether it is a valve or a piston.
The price is high, due to a dealer but they are guessing for the reason.
Oct 7, 2018 at 4:30 AM
CASIASADA
  • 16 POSTS
Yeah, that is a lot of money and I cannot afford that.
Oct 7, 2018 at 1:43 PM
Have them pinpoint the exact issue without pulling the heads. They should have done that anyway as part of the diagnostic.
Oct 7, 2018 at 1:45 PM
CASIASADA
  • 16 POSTS
Yeah, but they did not do that.
Oct 7, 2018 at 3:06 PM
You need to tell them to do this before you make any type of decision.
Oct 7, 2018 at 3:08 PM
