Engine has 140,000 miles after piston rings replaced and both heads done. Spark plugs and wires changed with new GM brand 6,000 miles ago. Now check engine blinks and traction control message pop up. The code P0300 showed up and acceleration is low to none at some point. Timing is getting lower from 15 to 16 degrees to 10 or 9 degrees when try to accelerate fast and cylinders five and seven show the most misfiring. When engine running at park position looks normal and does not show misfiring.
Any advise please?
Any advise please?
Jan 28, 2018 at 10:51 PM
