The inter-cooler is at the bottom of the radiator support. Here are the directions for removal and replacement. The attached pics correlate with the directions.
2015 Ford Fusion FWD L4-2.0L Turbo
Charge Air Cooler (CAC)
Vehicle Powertrain Management Fuel Delivery and Air Induction Turbocharger Inter-cooler Service and Repair Removal and Replacement Charge Air Cooler (CAC)
CHARGE AIR COOLER (CAC)
303-12B Intake Air Distribution and Filtering - 2.0L EcoBoost (184kW/250PS) - MI4 2015 Fusion
Removal and Installation
Removal
NOTE: Removal steps in this procedure may contain installation details.
image WARNING: Before beginning any service procedure in this section, refer to Safety Warnings in section 100-00 General Information. Failure to follow this instruction may result in serious personal injury.
Follow the health and safety precautions.
Refer to: Health and Safety Precautions (100-00 General Information, Description and Operation) .
With the vehicle in N , position it on a hoist.
Refer to: Jacking and Lifting - Overview (100-02 Jacking and Lifting, Description and Operation) .
Remove the retainers and the splash shield.
pic 1
Remove the retainers and the front under-body shield.
pic 2
Remove the retainers and the lower radiator support.
Torque : 18 lb.ft (24 Nm)
pic 3
Loosen the clamps and disconnect the CAC inlet and outlet tube.
Torque : 44 lb.in (5 Nm)
pic 4
Disconnect the electrical connector.
pic 5
Remove the bolts and the CAC .
Torque : 53 lb.in (6 Nm)
pic 6
Installation
To install, reverse the removal procedure.
__________________________
Hope that helps.
Jul 6, 2020 at 9:57 PM
