Hello, hope you had a good Christmas. Please bear with me this truck is a basket case. I have been doing this since 1980 and I can usually figure out can problems out, but this has got me stumped. i checked for grounds Ohomed the wires out between PCM and tac and between TPS and the tac and between the throttle petal actuator and the tac, had 5v reference at the 3 wires at throttle petal had 5v at tac module. I can clear all codes now and only p1518 is there, I can clear it too, but I have to do it twice. Engine will crank and run but throttle will not work, and engine will not turn off, I have been rewiring the wires out for days and I would like to know what the proper output at each wire going to the throttle body are supposed to be. Also, what is the voltage for serial is supposed to be coming off the PCM blue plug 14 and 15. This truck has been a problem. What am I missing? I have a blue driver, scanner and a Launch please point me in the right direction. Thanks
Jan 9, 2022 at 8:10 PM
