Codes p0123 p0420, p0300, p0302, and p0304?
2017 HYUNDAI ACCENT
145,000 MILES • 1.6L • 4 CYL • AUTOMATIC
SHORTSTACK1
On my girlfriend ‘s vehicle I recently scanned it because the check engine light came on and it had the P0 300 302 and 304 codes as well as the P0420 codes. I have replaced the spark plugs, the coil packs both catalytic converters the upstream or bank one sensor 102 sensor as well as the crank position sensor. And I was cleaning the throttle plate on it and now it’s giving me a code P0123 on top of it it’s no longer giving me a stored code or pending code for the P0420. however, it is still running rough and it’s giving me a pending P0304 and 30302. once in a while, but almost always a code 304. just looking for some help on that and maybe how to get it to relearn the position of the throttle it says voltage high.
Feb 24, 2025 at 4:16 PM
The first codes may cause the other codes BTW. The TPS sensor is inside of the throttle body.
Here is how to change it out in the images below.
P0123 - Throttle Position Sensor (TPS) "A" Circuit High Input
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0300 - Random/Multiple Cylinder Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
Please clear the codes once the repairs are complete. Check out the images (below). Let us know how it goes.
Feb 25, 2025 at 10:26 AM
SHORTSTACK1
So to be sure I understand, the TPS could cause the prior codes and cause the misfiring?
Feb 25, 2025 at 10:53 AM
Yes, the TPS affects mixture so if the cylinder is too lean it will misfire. If you want to be sure the engine is not having an issue first, let's do a compression test.
Feb 26, 2025 at 8:30 AM
