I have the car listed above that seems to be displaying all the symptoms of a faulty TPS - faulty shifting, not wanting to shift into last gear, rough idle, and code 0122 letting me know that the voltage is low on my TPS. I have replaced the sensor as well as the connector. I have tested the front of the connector as well as back-probed the wires. My ground and ref wires are solid. My sig wire is showing a voltage of .001-.003. I traced the wire to where it starts in the harness and tested a spot there with the same results. Besides a faulty PCM, could I test anything else?
Apr 9, 2018 at 5:40 PM
