Hi, I went ahead and took out everything in the way to replace the sensor to find the wires have come off from the pigtail connector, ordered another and installed it, confirmed via scanner that temp changes when I unplug it and plug it. Put back everything, now neither fan come on with ac on. I cannot tell if the compressor is kicking on or not as these are the types of compressors that does not have a front clutch like the old cars so I can't tell, and I don't hear anything clicking when I hit the ac button. I also remember the fans stay on high before I fixed the sensor wire, hence why I suspected that the ECT maybe faulty, and then confirmed with the scanner that there was a code for it, hence why I wanted to change it. but now neither fan come on. I checked the connector to the fan and I am getting both ground and power. Only code I have now is B10A915
Aug 6, 2025 at 1:27 PM
