Code p0011
2011 VOLKSWAGEN JETTA
235,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Do these camshaft codes always mean bad news? I see them on so many vehicles and was wondering if sole can be easily fixed. I always try to avoid them when buying cars, but they are so common, and some cars don't even have symptoms. Other similar codes are p0015, p0016, and others. I know sometimes it could be due to a bad sensor, dirty solenoids, dirty oil. What can be done to fix it if it's more than that, as in cam issues, i guess?
Nov 18, 2021 at 5:35 PM
DIVIDES
  • 903 POSTS
I also see them on both low and high mile cars.
Nov 18, 2021 at 5:36 PM
Cam codes are very common. However, replacing the sensor doesn't always fix the issue. The code you provided (P0011) indicates an issue with the variable valve timing being over-advanced. This can be the result of a camshaft adjustment valve being damaged, dirty, or plugged. Also, it is an electrical component, so wiring and electrical should be taken into consideration as a possible issue. Also, the ECM, in this case, could also be failing.
I hope this helps. Let me know if you have other questions.
Nov 18, 2021 at 8:21 PM
DIVIDES
  • 903 POSTS
Cam shaft adjustable valve, by that you mean the phaser?
Nov 19, 2021 at 5:16 AM
Yep, it is what controls the advance.
Nov 19, 2021 at 8:29 PM
DIVIDES
  • 903 POSTS
So, it's not that the timing is off its just advanced or retarded.
Nov 20, 2021 at 6:15 AM
Based on the code, it is advanced. This can be the timing belt also. Anything that can cause the timing to be too far advanced can set this code.
I hope this helps.
Nov 21, 2021 at 5:35 PM
