Code p0010
2011 CHEVROLET MALIBU
80,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROGERJRSS
  • 4 POSTS
The check engine light comes on along with traction control and esc.
Nov 9, 2018 at 9:58 AM
Good afternoon.
The code is for the camshaft actuator.
Below is the picture and procedure.
1. Remove the air cleaner outlet duct. Refer to Air Cleaner Outlet Duct Replacement (See: Air Cleaner Fresh Air Duct/Hose > Removal and Replacement > Air Cleaner Outlet Duct Replacement).
2. Disconnect the engine wiring harness electrical connector (1) from the exhaust camshaft position (CMP) actuator solenoid valve (4), if required.
3. Disconnect the engine wiring harness electrical connector (2) from the intake CMP actuator solenoid valve (3), if required.
4. Remove the exhaust (1) CMP actuator solenoid valve bolt and valve, if required.
5. Remove the intake (2) CMP actuator solenoid valve bolt and valve, if required.
6. Inspect the solenoid valve O-ring seals for damage, replace as necessary.
Nov 9, 2018 at 10:13 AM
ROGERJRSS
  • 4 POSTS
I also have p0106 and p0107 can they all be related?
Nov 9, 2018 at 10:57 AM
106 and 107 are mass air flow sensor codes.
Make sure the connector is good and tight. Also, make sure the hose from the sensor to the throttle body has no leaks.
P0106
Descriptor
Probable Causes
Air Intake System
Engine Control Module (ECM)
Exhaust System
Manifold Absolute Pressure (MAP) Sensor
Manifold Absolute Pressure (MAP) Sensor Port
Vacuum Hose/Line
Nov 9, 2018 at 11:37 AM
ROGERJRSS
  • 4 POSTS
Traction control and esc maintenance light up in the odometer. Also engine light the car also misfires.
Nov 9, 2018 at 12:28 PM (Merged)
