CODE P0001
2000 CHEVROLET IMPALA
220,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
PMASSINGILL47
  • 10 POSTS
My car just quit running on me in traffic as I was driving along it quit no warning no check engine light. I could not get it started right away finally it did but I had to give it gas. I got home put my obd2 reader on it anyway it brought up the P0001 code. so I put a fuel pressure regulator on it and coils and module and air filter. when I start it after it warms up it shuts off, I start it back up it runs a few minutes and sounds okay when it is running. I cannot figure it out.
Aug 1, 2017 at 5:02 PM
That code is a communication error that usually means the computer has gone bad and needs replacement. If you get a new one it will need to be programmed but a used one should plug and play.
Here is the location of the PCM (below).
Aug 2, 2017 at 7:39 PM
PMASSINGILL47
  • 10 POSTS
If I get a new PCM how can I program it?
Aug 2, 2017 at 8:22 PM
A shop or the dealer must do it. Unless you have a scanner that can reprogram.
Aug 3, 2017 at 10:14 AM
PMASSINGILL47
  • 10 POSTS
Okay thank you. I think i will get a used one.
Aug 3, 2017 at 11:04 AM
PMASSINGILL47
  • 10 POSTS
Oh I am sorry I wanted to thank you for helping me. I will get the ECM try that and see how it goes and post back later.
Aug 3, 2017 at 11:05 AM
Please do :)
Aug 3, 2017 at 4:04 PM
