Code for catalytic converter
2004 LINCOLN LS
168,000 MILES • 3.0L • V6 • AUTOMATIC
DGPETERSON
My engine code popped up with a catalytic converter I am having that replaced. Except I am have trouble with other stuff also from oil leak coolant leaks and so on. My question is it because I haven’t replaced the converter for the other problems?
Aug 5, 2019 at 6:27 PM
Good evening,
No, not at all. The converter is a separate issue form all the leaks. They need to be tested individually for the source of the leaks.
https://www.2carpros.com/articles/engine-is-leaking-oil
https://www.2carpros.com/articles/car-is-leaking-coolant
Follow the guides to help you determine the source of the leaks.
Aug 5, 2019 at 6:51 PM
