code for AIT RICH FUEL MIXTURE AND ANOTHER CODE FOR IGNITER RUFF IDLE
1992 TOYOTA PASEO
250,000 MILES • 4 CYL • FWD • MANUAL
JJANTHONY13
My girfiend has this old grocery getter and all of a sudden it starts sounding like an old vw beetle bug. Ruff idle and just sounds bad .check engine light was on I jump the diagnostic box and pulled 24.25.43.. I need some helpful knowlage .I've done hours of research and can not figure it out? Please someone HELP US GET GOIING AGIAN
Nov 24, 2015 at 12:34 AM
CARADIODOC
  • 34,306 POSTS
'95 and older vehicles have a rather basic fault code system. I can help with the intake air temperature sensor, but first, start with the basics. Look at the spark plugs and wires if you have a misfire or rough running engine. The sensors just tweak the fuel metering calculations and aren't likely to cause a major running problem. Very often the only way to know there's a problem is by the fault codes.
Here's the page for the fault codes:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Nov 24, 2015 at 1:08 AM
