Code 84 noticeable loss of engine power began making a tripping?
2019 CHEVROLET SONIC
135,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
JWILKINSON0727
I have a 2019 Chevy Sonic that was experiencing Code 84 and a noticeable loss of power, which was the vehical going into limp mode. I found that it could be the throttle position sensor or pedal position sensor or fuel filter fuel pump fuel module, which is all one anyway on my car. So I started with the position sensor, which is connected to the throttle body and has to be bought as one piece so I bought a brand new from O’Reillys then I installed it just as the other one installed we did not however change out the gasket because it seemed to be in good shape. Once the throttle body was changed, the car started and ran fine initially, and the power issue seemed resolved. It is making a weird chirping noise when the heater is on and it’s very cold here in Oklahoma currently I might add. Want to say this I am not a mechanic but I work as a pipe fitter and have years of mechanical experience, so that being said, I am not a mechanic and watched a video on how to do it, but I’m also not a jackass. However, shortly after the repair, the engine began making a tripping and I’m now trying to determine what that noise could be and whether it’s related to my installation of the throttle body or something else. The car has had several issues since I bought it but it’s what I have and currently don’t have any other options but to make this work! I will leave the video , any help is appreciated thank yall for your time.
Jan 30, 2026 at 2:17 PM
So the car is going into limp mode, the #1 reason this happens is the throttle body needs to be cleaned or replaced which you did so I assume that problem is fixed and he problem now seems to be a noise? I don't see the video can you please re-upload it so I can hear it? .
Code 84 - reduced engine power (limp mode)
Also, is the noise coming from the serpentine belt area? If so this can be the belt or tensioner that needs to be replaced. It could be a vacuum leak as well, does the noise go away when you snap the throttle? if so I would do a vacuum leak test.
https://www.youtube.com/watch?v=xN5pcM-5bso
Jan 31, 2026 at 9:46 AM
STEVE W.
  • 15,113 POSTS
Try this test, Turn on the key and then turn on the heater blower, any chirping noise? Asking because a bad blower motor bearing or blower fan contact could be a chirp. Nothing? Then start the engine and turn the blower on high, headlights on high and window defrosters on. Now is it chirping? Yes, then use a spray bottle or just drip some water on the serpentine belt. Very possible that something got on the belt while you were working on it and it is causing the chirp. The water will tell you if it's the belt as it should change the sound.
Jan 31, 2026 at 11:03 AM
