E4OD is transmission shifting rough. Code 452, 632 from KOEO/KOER. I cannot find a VSS on the transmission. There is a hole for one that is plugged and not used on the transfer case. My speedometer works fine. Is the PCM getting its VSS signal from the rear axle VSS? Would the speedometer not stop working then?
Jan 2, 2018 at 11:50 AM
