Code 41
1992 DODGE DAKOTA
232,000 MILES • 3.9L • V6 • 2WD • MANUAL
GARYSIMPSON
  • 22 POSTS
Code 41 came on. cuts out and check engine light came on. Also code 12 but i never disconnected the battery. volt gauge is now like 10 battery six months old.
Dec 30, 2018 at 9:14 AM
Good morning,
You need to charge your battery. it needs to be at 12.4 to 12.6 volts.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
code 12 is low voltage and 10 volts will set the code.
code 41 is for the charging system. it could be either the alternator or the voltage regulator.
NOTE: Information provided for those with no access to scan tool. In order to properly diagnose and repair vehicle, scan tool should be used.
FAULT CODE NO. DRB II DISPLAY DESCRIPTION OF FAULT CONDITION
11 IGN reference signal No distributor reference signal detected during engine cranking.
12 No. of key-ON's since last Direct battery input to controller disconnected with the last 50
fault ignition key-on cycles.
13 MAP pneumatic signal No variation in MAP sensor signal is detected.
or
MAP pneumatic change No difference is recognized between the engine MAP reading and the stored barometric pressure reading.
14 MAP voltage too low MAP sensor input below minimum acceptable voltage.
or
MAP voltage too high MAP sensor input above maximum acceptable voltage.
15 Vehicle speed signal No distance sensor signal detected during road load conditions.
16 Battery input sense Battery voltage sense input not detected during engine running.
17 Low engine temp Engine coolant temperature remains below normal operating temperatures during vehicle travel.
21 Oxygen sensor signal Neither rich nor lean condition is detected from the oxygen
or sensor input.
02 sensor shorted high Oxygen sensor input voltage maintained above normal operating range.
22 Coolant voltage low Coolant temperature sensor input below the maximum acceptable
or voltage.
Coolant voltage high Coolant temperature sensor input above the maximum acceptable voltage.
23 Throttle body/Charge temp Throttle body/charge temperature sensor input voltage below the
sensor voltage low minimum acceptable standard.
24 TPS voltage low Throttle position sensor input below the minimum acceptable
or voltage.
TPS voltage high Throttle position sensor input above the maximum acceptable voltage.
25 AIS motor circuits A shorted condition detected in one or more of the AIS control circuits.
26 INJ 1 peak current High resistance condition detected in the INJ 1 injector bank
or circuit.
INJ 2 peak current High resistance condition detected in the INJ 2 injector bank
or circuit.
INJ 3 peak current High resistance condition detected in the INJ 3 injector bank circuit.
27 INJ 1 control circuit Injector 1 output driver does not respond properly to the
or control signal.
INJ 2 control circuit Injector 2 output driver does not respond properly to the
or control signal.
INJ 3 control circuit Injector 3 output driver does not respond properly to the control signal.
31 Purge solenoid circuit An open or shorted condition detected in the purge solenoid circuit.
32 EGR solenoid circuit An open or shorted condition detected in the EGR solenoid
or circuit.
EGR system failure Required change in fuel/air ratio not detected during diagnostic test. (California emissions packages only.)
33 A/C clutch relay circuit An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
34 S/C solenoid circuits An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
35 Radiator fan relay An open or shorted condition detected in the radiator fan relay circuit.
36 Wastegate solenoid circuit An open or shorted condition detected in the wastegate solenoid circuit.
37 PTU solenoid circuit An open or shorted condition detected in the torque converter part throttle unlock solenoid circuit. (Auto transmission only.)
41 Alternator field circuit An open or shorted condition detected in the alternator field control circuit.
42 ASD relay control circuit An open or shorted condition detected in the auto shut down relay circuit.
43 Ignition coil control Peak primary circuit current not achieved with maximum dwell
circuit time.
44 FJ2 voltage sense No FJ2 voltage present at the logic board during controller operation.
45 Overdrive solenoid An open or shorted condition detected in the overdrive solenoid circuit. (Auto trans only.)
46 Battery voltage high Battery voltage sense input above target charging voltage during engine operation.
47 Battery voltage low Battery voltage sense input below target charging voltage during engine operation.
51 Lean F/A condition Oxygen sensor signal input indicates lean fuel/air ratio condition during engine operation.
52 Rich F/A condition Oxygen sensor signal input indicates rich fuel/air ratio condition
or during engine operation.
Excessive leaning Adaptive fuel value leaned excessively due to a sustained rich condition.
53 Internal controller failure Internal engine controller fault condition detected.
or
Controller failure SPI No internal communication between coprocessors.
communications
54 No sync pick up signal No fuel sync signal detected during engine rotation.
55 N/A Completion of fault code display on check engine lamp.
62 EMR mileage accum Unsuccessful attempt to update EMR mileage in the controller EEPROM.
63 EEPROM write denied Unsuccessful attempt to write to an EEPROM location by the controller.
77 Speed control power relay An open or shorted condition detected in the speed control
circuit power relay circuit.
N/A Fault code error An unrecognized fault ID received by DRB II.
Dec 30, 2018 at 9:40 AM
