Had several codes which are shown. Deleted all and restarted and only have this code 2f52 with no check engine light.
Dec 22, 2023 at 9:37 AM
CERTIFIED EXPERT
Here is information on the code:
The fault code 2F52 "Super knocking detection."
Does the engine run? We need more information to help you. If the engine runs and sounds okay, I would lean towards a bad PCM. Can you upload a video of the engine cranking over/running please?
Dec 22, 2023 at 12:32 PM
BHAMDOC1973
MEMBER
Car drives fine yes.
Dec 22, 2023 at 12:58 PM
CERTIFIED EXPERT
Okay, let's swap out the knock sensor to see if that fixes it which it should. Here is the location of the sensor. Also, the sensor might just be loose, which will cause this problem as well. Check out the images (below). Let us know how it goes.
Dec 23, 2023 at 10:27 AM
BHAMDOC1973
MEMBER
Okay, will do. Why is it that they can go bad without a knocking engine? Isn't its job to give out the code when there is a knock? I replaced many on different cars that had zero issues and it made a day and night difference.
Dec 23, 2023 at 12:56 PM
CERTIFIED EXPERT
The codes will only come up when the knock cannot be controlled. Let us know after you check out the sensor.
