Today I got the master cylinder of my car listed above changed at a mechanic.. After it was done it drove normally.. however this evening i started the car and pressed the clutch and it felt very loose.. moreover, the gears didn't shift in... after trying again i managed to shift the gear in and drive.. However the clutch is still very loose.. the only way I can explain is that its similar to when you changed the clutch cable..
My question is, is it normal for a clutch to become very loose after changing a master cylinder?
Thanks!
Thanks!
Sep 4, 2019 at 3:52 PM
