Okay, the quality of the parts could be an issue. A lot of times, aftermarket parts are cheaper than OEM but do not last as long as the original equipment.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
I could not read the invoice for the type or manufacturer of the master and slave.
Bleeding
1. Attach a clear line to the bleed screw with the loose end submerged in a small container of clutch fluid.
2. Actuate the clutch pedal 5 times at a normal speed by stroking it all the way to the pedal stop in both directions.
3. Actuate the clutch pedal quickly 10-15 times without bringing the pedal all the way up, 30-40 mm (1.18-1.51 inch) short of stop at pedal.
4. Repeat steps 2-3 5 times.
5. Hold the pedal at up stop and open the bleed screw.
6. Stroke the pedal to the floor normally and close the bleed screw.
7. Lift the pedal to up stop position.
8. Repeat steps 5-7 3 times.
Notice: Refer to Fastener Notice in Cautions and Notices.
9. Tighten the bleed screw.
Tighten the screw to 7 Nm (62 inch lbs.).
10. Remove the bleed line from the bleed screw.
Clutch Master Cylinder Replacement
Removal Procedure
1. Clean the clutch fluid reservoir cap and area around the cap.
2. Remove the clutch fluid reservoir cap and remove enough brake fluid to clear a passage to the clutch master cylinder.
3. Remove the clutch pedal retainer.
4. Remove the clutch master cylinder pushrod from the clutch pedal assembly, 1st design.
5. Remove the clutch master cylinder pushrod from the clutch pedal assembly, 2nd design.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in Cautions and Notices.
6. Place a shop towel under the clutch master cylinder in order to catch any fluid loss.
7. Using a pick tool on the strut tower side, disconnect the clutch line from clutch master cylinder.
8. Cap the reservoir and hydraulic lines in order to prevent fluid loss and contamination.
Important: Do not damage the pushrod boot when sliding it through the front of the dash.
9. Remove the clutch master cylinder mounting nuts and slide the clutch fluid reservoir up and out.
Jan 3, 2021 at 2:44 AM
