Clutch slipping after replacement
2014 CHEVROLET CRUZE
115,000 MILES • 1.8L • 2WD • MANUAL
BTEC2012
  • 6 POSTS
I changed the clutch in my car and after I got done I used a vacuum pump to bleed the clutch off the slave cylinder that’s on the transmission. started it up it shifted gears good while stationary, but when I put it in gear it budges like an inch then slips makes the same sound it did before I changed it. here is the picture of the old clutch. I didn’t think it was all that worn, it’s rough and has hot spots but I don’t think it was time to fail.
Feb 16, 2019 at 10:56 AM
Good afternoon,
No pictures attached. Can you re attach?
Can you see if the release bearing is fully releasing? I am concerned about the throw-out bearing?
Feb 16, 2019 at 1:01 PM
BTEC2012
  • 6 POSTS
It has a concentric slave for. The throw-out bearing the pedal feels right, but I have no sea how to tell if it is working. I’m working on rearing it apart to see if I may have accidentally put the clutch on backwards or got the torque wrong.
Feb 16, 2019 at 1:38 PM
If you put the disc in backward, it would not go into gear at all. It will scrape and make a bad noise.
I assume you did replace the throw-out bearing as it is the slave as well?
Feb 16, 2019 at 1:45 PM
BTEC2012
  • 6 POSTS
Yea, I did replace the throw-out bearing but I didn’t replace the slave on the outside of the transmission where you bleed the clutch. I am a GM tech I seen at the eye doc told me it could be that.
Feb 16, 2019 at 2:11 PM
Most definitely. It is not allowing the bearing to release.
Feb 16, 2019 at 2:26 PM
BTEC2012
  • 6 POSTS
Okay, thank you so. i will try that. Before this all happened there was a cdv valve on it and I read on line it drives a lot better with out it. so I took it out. do you think this has caused the whole problem?
Feb 16, 2019 at 3:23 PM
Possible. I would reinstall it and check it.
Feb 16, 2019 at 3:25 PM
BTEC2012
  • 6 POSTS
Okay, thanks for all your help.
Feb 16, 2019 at 7:30 PM
You are welcome.
Always glad to help.
Feb 17, 2019 at 3:01 AM
BTEC2012
  • 6 POSTS
I took it all apart and found the culprit the dual mass flywheel seems. Broke the part the pressure plate bolts to is spinning freely and the new DMFlywheel I ordered (which is the wrong size unfortunately, they sent the first design 8.5 inch I need the second design 9”). It does not spin freely there seems to be springs or something in it to keep it with the flywheel. A least I found the problem.
Feb 21, 2019 at 2:53 PM
Good find.
Feb 21, 2019 at 3:21 PM
