Clutch set replaced
1984 DODGE TRUCK
200,000 MILES • 5.2L • V8 • 2WD • MANUAL
MARTINSDODGE
Had someone replace the clutch, pressure plate and throw out bearing and now it will not go into gear while truck is running. Was wondering where I should start to find the problem?
Jul 22, 2018 at 9:26 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
After having a clutch replaced sometimes the mechanical linkage your truck has needs to be adjusted just for this reason. When adjusting try to get it adjusted to engage in the middle of the pedal travel.Too close to the top runs the risk of burning up new clutch and too far to the bottom it will not engage (problem you are having). Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 23, 2018 at 12:58 AM
MARTINSDODGE
Thank you. I will try it
Jul 24, 2018 at 10:18 AM
DANNY L
  • 5,648 POSTS
Hello again.
You are welcome. Let us know how things turn out or if you ave any further questions.Thanks again for using 2CarPros.
Danny-
Jul 24, 2018 at 10:06 PM
