How to detach the clutch rod from the transmission?
1999 VOLKSWAGEN CABRIO
111,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SETH7383873
MEMBER
FOLLOW
Working on rebuilding the shifter but cannot figure out how to detach the clutch rod from the transmission
Oct 11, 2020 at 4:21 PM
CERTIFIED EXPERT
I am attaching the entire process for your review to see if you are missing a step.
Also, I included the exploded view of the shifter that may help identify what you are missing. Let us know what questions you have or how you make out. Thanks
Oct 11, 2020 at 4:32 PM
SETH7383873
MEMBER
It is for a automatic i need manual.
Oct 11, 2020 at 5:19 PM
CERTIFIED EXPERT
So sorry. I am just used to answering that question for auto transmissions. Here is the process for a manual.
Let me know how you make out.
Oct 12, 2020 at 7:23 PM
SETH7383873
MEMBER
Thank you! Have one more question though, what is the part between 16 and 17? The guy I bought it from really did a number on this thing and cut that part and needs to be replaced. Thanks!
Oct 15, 2020 at 3:24 PM
CERTIFIED EXPERT
Just so I am clear, this part that I circled? If so, that is part of the spring pin (16). However, I am not confident that you will find just that part. You may need to get the shifter assembly or find a salvage yard that has one and will let you take just that piece.
Image (Click to enlarge)
Oct 15, 2020 at 8:09 PM
SETH7383873
MEMBER
Thank you!
Oct 15, 2020 at 10:17 PM
CERTIFIED EXPERT
You are welcome. Please come back to 2CarPros next time you need some help. Feel free to ask a new question with whatever comes up. Thanks
