clutch replacement torque specs needed?
2001 BMW 330CI
150,000 MILES • 6 CYL • 2WD • MANUAL
BHAMDOC1973
  • 2,008 POSTS
Replacing the clutch on this car listed above convertible. I need the torque specs for the following:
Dual mass flywheel bolts
Pressure plate bolts
Rear main seal bolts
Aug 22, 2024 at 5:29 AM
Sure, here are the torque specs you have requested.
Manual transmission flywheel to crankshaft S62 / M62 / M62TU - Do not install with screw retaining compound. Bolts are a component of the flywheel.
Oil screw threads. 105 Nm
Manual transmission flywheel to crankshaft M44 / M73 / M73TU
Replace screws 120 Nm
All others Replace screws 105 Nm
Automatic transmission flywheel to crankshaft
All Replace screws 120 Nm
Clutch to Flywheel
M8 Bolts [Grade 8.8] 24 Nm
M8 Bolts [Grade 10.9] 34 Nm
They don't say what the rear main housing bolts are. Let us know if you need anything else.
Aug 22, 2024 at 10:42 AM
BHAMDOC1973
  • 2,008 POSTS
S62 / M62 / M62TU I think these are for v8s.
Aug 22, 2024 at 10:47 AM
BHAMDOC1973
  • 2,008 POSTS
Mone i think is the zf.
Aug 22, 2024 at 11:17 AM
This is for the 6 cylinder I rechecked it.
Aug 23, 2024 at 7:04 AM
BHAMDOC1973
  • 2,008 POSTS
I checked. All of them are for v8s except the m44 which is a 4 cylinder It's on Wikipedia and many other sites. I am very familiar with these numbers too, that's why i asked. The 6-cylinder inline are usually the m54 abd m52.
Aug 23, 2024 at 7:22 AM
Sorry, my bad I was looking up the convertible. Here is the inline 6 cylinder:
Manual transmission flywheel to crankshaft S62 / M62 / M62TU - Do not install with screw retaining compound. Bolts are a component of the flywheel. Oil screw threads. 105 Nm
Clutch to Flywheel
Aug 23, 2024 at 8:54 AM
BHAMDOC1973
  • 2,008 POSTS
S62, m62 are v8s.
Aug 23, 2024 at 9:05 AM
Hmm, Alldata must have it wrong, sorry.
The 2001 BMW 330Ci does not come with the S62 or M62 V8 engines. Instead, it is equipped with the M54 inline-six engine.
Aug 23, 2024 at 1:18 PM
BHAMDOC1973
  • 2,008 POSTS
Yes, I know, that is why I am hesitant to use these numbers.
Aug 23, 2024 at 2:35 PM
I don't blame you, do you know of another car that has this engine? I can try looking that up.
Aug 24, 2024 at 9:44 AM
BHAMDOC1973
  • 2,008 POSTS
All BMW 3 series 2000-2006, and 525 same years.
Aug 24, 2024 at 10:03 AM
This is what they show, check out the images (below).
Aug 24, 2024 at 10:23 AM
