I replaced the clutch master and slave (throw out bearing), new pressure plate and everything, the old stuff was shot. I put the transmission back on and bleed the system. the clutch pedal is nice and firm so I know I have good pressure, but it will not engage. I can feel it shift gears fine everything in the transmission is engaging it is just not grabbing when I release the clutch. the throw out bearing had a plastic tie on it that said not to cut that it would release on its own. I am getting fluid through everything and all the air is out but it will not go into gear to drive.
Oct 27, 2017 at 12:40 PM
