Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Drivetrain
Transmission
Clutch
Pedal
I push the clutch pedal about halfway down it makes a grinding
2004 DODGE RAM
170,000 MILES • 3.7L • V6 • 2WD • MANUAL
C89ROBINSON
MEMBER
FOLLOW
When I push the clutch pedal about halfway down it makes a grinding or rubbing sound it will not shift.
Jul 17, 2019 at 10:47 AM
CERTIFIED EXPERT
Good afternoon,
Sounds like the throw-out bearing in the clutch has failed.
You will need to remove the transmission and inspect the bearing, pressure plate and disc.
https://www.2carpros.com/articles/how-to-replace-a-clutch
May 1, 2021 at 6:26 PM
C89ROBINSON
MEMBER
Thank you. I was thinking the exact same thing but wasn't sure if i was right. I really appreciate your help.
CERTIFIED EXPERT
You are welcome.
Always glad to help.
CERTIFIED EXPERT
I got an email that you responded but nothing came through.
Can you resend?
