Clutch problem
1994 HONDA WAGOVAN
180,000 MILES • 4WD • MANUAL
INACAMPBELL
My car has a five speed transmission. It is not going into first gear or reverse gear when i start the engine. I have to warm it up for at least ten minutes before it actually goes into gear. It just started to do this. It was running smooth and easy gear changing for last couple of years.
Oct 29, 2017 at 12:29 AM
Your clutch disc is fallen apart which causes the clutch not to fully disengage because the disc cannot stop allowing the gears to be changed. Here is a couple of guides that will help you see what you are in for and to show you how it all works.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
and
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
and
https://www.2carpros.com/articles/how-to-replace-a-clutch
You car will be different but it gives you the idea.
Oct 30, 2017 at 2:02 PM
