I have replaced everything new on the clutch system, but the clutch won't engage fully, you can force it in gear, but the wheels are still turning. I know it's not a hydraulic problem because I have the slave cylinder pushed in with a puller and the pedal is rock solid. Everything being flywheel, clutch, pressure plate, throw-out, bearing, clutch fork, slave cylinder, master cylinder. This has the pull pressure plate system. It seems to me it`s not pulling enough.
Jul 3, 2022 at 1:35 PM
