I have a problem with my clutch. The pedal got heavy then I lost the clutch. The slave cylinder push rod has broken in two and leaked all the fluid. However, with the engine running I can still put in gear but nothing happens (would like expect with no hydraulic fluid the clutch to be permanently engaged and be unable to put in gear). I suspect something has broken inside the actual clutch. What is this most likely to be?
Jul 28, 2018 at 11:41 AM
