Clutch pressure plate
1984 NISSAN 300ZX
95,000 MILES • 3.0L • V6 • 2WD • MANUAL
JOEPOTTER531
The car was flooded. I have replaced the slave cylinder and cleaned all tubes. I'm thinking that the pressure plate is rusted stuck. Also, I'm not exactly sure how to get to the pressure plate in order to get it unstuck.Help!
May 16, 2019 at 5:29 PM
Good morning,
The transmission would have to be removed. At that point, it would be best just to replace the clutch assembly.
https://www.2carpros.com/articles/how-to-replace-a-clutch
1. Remove transmission.
2. Insert a dummy shaft into the clutch disc hub.
3. Loosen clutch cover attaching bolts alternately.
4. Remove clutch disc and cover assembly.
5. Remove release bearing.
6. Reverse procedure to install.
May 17, 2019 at 4:37 AM
