Losing pressure at clutch pedal
2016 VOLVO S80
90,000 MILES • 2.2L • 5 CYL • 2WD • MANUAL
TURNER199
Pump a few times and okay for a few miles then drops to floor and have to lift and pump again. No loss of clutch fluid. Could it be an air leak or does slave cylinder need replacing inside gear box?
Sep 14, 2019 at 7:41 AM
Welcome to 2CarPros.
It could be the slave or the clutch master cylinder. I have to be honest, leaks are the most common reasons for the slave to fail. On the master cylinder, the plunger may be failing and allowing fluid to bypass and require you to pump the clutch pedal.
Since the fluid is full, my first suspect is the clutch master cylinder. However, you may want to try bleeding the system first to make sure that is the issue.
Is the year you listed correct?
Sep 14, 2019 at 8:29 PM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. As JACOBANDNICKOLAS stated, is this the correct vehicle? In the USA market there is no manual transmission S80.00 that I know of? Can you provide a VIN # in a private message to profile the vehicle?
Sep 15, 2019 at 10:20 PM
TURNER199
Didn’t realize I was dealing with USA, yes manual, just leave it
Sep 24, 2019 at 8:32 PM
Not a problem. Let me know if you do need help. The clutch hydraulics are very similar on most vehicles.
Sep 25, 2019 at 4:58 PM
