Clutch plate replacement
2007 MITSUBISHI SHOGUN
90,000 MILES • 3.0L • V6 • 4WD • MANUAL
GORAN BEZANOV
I was told that since the gearbox is quite heavy, it is best to take the engine out in order to change the clutch. It seems like a lot of works to replace the clutch. I have never changed a clutch plate o an 4x4. so I am not sure if it can be done in a conventional manner by uncoupling at the bell housing from the engine, decoupling the prop-shaft and moving the gearbox away to allow access to plate and diaphragm. Thank you in advance.
Aug 3, 2019 at 10:45 PM
They do not give us much on this repair. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Then I can look at it tell help you with the repair. Please let me know.
Aug 5, 2019 at 1:33 PM
