clutch pedal will not move when pressed
1994 FORD RANGER
120,000 MILES • 4.0L • V6 • 4WD • MANUAL
DANIEL SPENCER
Just installed new clutch in the truck listed above and put the transmission back in. Now the clutch pedal will not move when pressed. No idea why or what i need to do to fix it. Really don't want to take the transmission out again but if I have to I will. Anyone know what i need to do?
Dec 12, 2020 at 12:00 AM
This is a bit of a unique issue because you have a hydraulic clutch system. So normally when there is an issue the pedal will depress but not return or release the throw out bearing.
If it will not depress then I would think something has to be blocking the pedal, master cylinder, or throw out bearing/pressure plate.
I would doubt there is an issue with the hydraulic system if you have not bled the clutch yet so I would reinspect the master cylinder and pedal connection and make sure there is nothing blocking it.
Here is a guide that talks about the throw out bearing which may be part of the issue:
https://www.2carpros.com/articles/throw-out-bearing-replacement
Dec 12, 2020 at 4:05 PM
