Hi, I have had a few problems with the clutch pedal sinking whilst driving. It used to sink to the floor completely and I had to kick it back up manually to be able to use it. So, I’ve had a new master and slave cylinder, a new clutch and flywheel (about 3,000 miles ago) and also had it bled three times. It was fine for a little while however I have noticed now it still sinks sometimes, about two inches lower than it usually sits and sometimes feels a lot lighter to press. Engaging and disengaging the clutch seems to be fine, and I can get it in and out of gear no problem. The car drives fine, but when I go to press the pedal it’s a lot lower occasionally and also affects the biting point. Any advice?
Dec 22, 2021 at 11:11 AM
