I recently changed the clutch and flywheel in my vehicle and upon reinstallation, I purchased a new battery to be safe. I noticed at first that the clutch pedal "pops" down to the floor board with absolutely no pressure, and in order to get it up, I have to apply light pressure from the back to "pop" it back up towards the driver.
So, with the clutch pedal (with no pressure) depressed, the car cranks and cranks, but will not fire up. Starter is ok, new battery, alternator is fine and everything power wise worked great before the install.
I probably need to bleed the slave and master cylinders, but with absolutely no pedal pressure, the system won't seem to pressurize after pumping and pumping. Would this be a reason it wouldn't start?
Sep 27, 2020 at 12:10 PM
