Clutch pedal
2004 HYUNDAI SONATA
142,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
OUTLAWZIMMORTAL
Changed clutch master cylinder and slave cylinder after the original clutch master cylinder went out pedal goes to floor when the bleeder is open close the bleeder pedal pops up then gets hard to push I do if I don't have it adjusted just right no slipping from transmission at all how can I fix without replacing clutch
Nov 27, 2018 at 5:58 PM
It sounds like you have a clutch disc that is falling apart holding the pressure plate from fully releasing. Here is a video and guide on a similar car that shows how to remove the transmission and replace the clutch:
https://youtu.be/6N6b5F2ChyE
and
https://www.2carpros.com/articles/how-to-replace-a-clutch
Nov 29, 2018 at 11:49 AM
